Tea Tray
Aussie
Model of CNC Machine: Axiom AR6 Pro
Tea Tray
Post by Aussie »
This tray is a resin filled DM model African Safari No1 depth of resin 9mm
Material Used:
Model Base - Oak
Sides - Canarywood
Splines - African Walnut
Handles - River Redgum
Tray Size
X - 480mm Y - 380mm Z - 70mm
Ron
Crafers Crafts
Re: Tea Tray
Post by mtylerfl »
That’s really great, Ron!
Todd Bailey
Vectric Staff
Model of CNC Machine: CraftCNC
Re: Tea Tray
Post by Todd Bailey »
Look simply amazing!!!! Well done!
I think the whole project came together very nicely. The resend covered relief carving is a great idea!
Thanks again for sharing!!!!
Todd Bailey | Design and Make
DesignAndMake.com
garylmast
Re: Tea Tray
Post by garylmast »
Great looking job!
Gary
gad5264
Model of CNC Machine: GarageWorX 18"x24"' using VCarvePro V10
Re: Tea Tray
Post by gad5264 »
Having a wife that absolutely loves giraffes, can I ask where you got the file for this amazing project?
Grant "gad5264"
Westerville, OH
PRO4824
Model of CNC Machine: AVID PRO4824
Re: Tea Tray
Post by PRO4824 »
Really nice Ron! Thanks for sharing and inspiring. 👍
Isaiah 41-10
Holzarbeiter
Model of CNC Machine: Camaster Stinger SR24
Re: Tea Tray
Post by Holzarbeiter »
Wow, Ron, that came out beautiful! Thanks for putting a future project in my mind...and for sharing.
Joe
TomWS
Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Re: Tea Tray
Post by TomWS »
Aussie wrote:
Mon Mar 08, 2021 5:21 am
depth of resin 9mm
Very nice work! What method did you use to eliminate bubbles in the resin?
Aussie
Re: Tea Tray
Post by Aussie »
TomWS wrote:
Tue Mar 23, 2021 2:13 pm
depth of resin 9mm
Depending on the brand of resin I am using, mostly a heat torch for surface bubbles, I do heat the resin in a water bath to make it flow easier and reduce bubbles.
I do have a vacuum pot ( still experimenting with it)
Ron
Crafers Crafts
TomWS
Re: Tea Tray
Post by TomWS »
Aussie wrote:
Tue Mar 23, 2021 10:19 pm
Interesting. I would have expected that the large surface area of the Oak, with all its pores, would have generated BILLIONS of bubbles. In any case, very nice piece.
Re Vacuum pump, you may actually want to try a pressure pot instead. Vacuum on Oak will suck all the air out of all those pores into your resin - DAMHIKT! I can show you some really fascinating permanently hardened bubble 'collections'. At least my 2 1/2 year old granddaughter finds them fascinating :lol:
Aussie
Re: Tea Tray
Post by Aussie »
TomWS wrote:
Wed Mar 24, 2021 3:43 am
Don't worry I have plenty of duds as well....
I prepare the surface after carving with 2 coats of sanding sealer followed by a very thin coat of epoxy before the deep pour, just have to take care of any surface bubbles with a torch.
A pressure pot is next on my list, not sure if a short period of time under pressure will eliminate the bubbles.
This is what I am currently working on and will be resin filled.
Ron
Crafers Crafts
TomWS
Re: Tea Tray
Post by TomWS »
Aussie wrote:
Wed Mar 24, 2021 4:22 am
Yes, I think you've got it covered! Good approach. I've seen that technique used in turning encapsulated burls as well.
It's my understanding that a pressure pot collapses the bubbles to where they're not easily visible and can be effective even with 7 minute set times.
Very nice. I'm new to VCarve and I'm looking forward to my first carving. I've got a few files ready to go, but haven't gotten the shop time to do them yet.
Cheers.
Creation in Wood
Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
Re: Tea Tray
Post by Creation in Wood »
Great job
Thank You
Doug
