Made this the past couple of days , but not sure its very good. May have to try it again. Looks OK but the red isnt quite right.
Dave
Epoxy emblem for Son-in-law
Re: Epoxy emblem for Son-in-law
Great use of color!
- scottp55
Pic is a little blurry, but it looks Great to me Dave!
What size is that?
The detail is Wonderful!!
What size is that?
R.N.
R.N.
- Aussie
- Model of CNC Machine: Robotics Model 8
Very nice... I am doing a lot of resin filled V Carves at the moment.
What depth of cut are you using and bit?
Ron
Crafers Crafts
Crafers Crafts
- Model of CNC Machine: Probotix Meteor 25 x 50
Thanks all. It's 10 1/2 inches round Scott. It was still wet when I took the pic I think is why it came out blurry, trying to keep the glare off it. Its cut 1/8 deep with a 60 degree v-bit. The red in the date's was filled like the rest, but when it dried it wasn't filled. I mixed a little more and did it again but still didn't fill. It really does look OK to a normal person, but I guess I'm still wanting to be a perfectionist.
Dave
Dave
- Aussie
Don't understand why it didn't fill ?woody53 wrote: ↑Sun Nov 01, 2020 2:15 pmThanks all. It's 10 1/2 inches round Scott. It was still wet when I took the pic I think is why it came out blurry, trying to keep the glare off it. Its cut 1/8 deep with a 60 degree v-bit. The red in the date's was filled like the rest, but when it dried it wasn't filled. I mixed a little more and did it again but still didn't fill. It really does look OK to a normal person, but I guess I'm still wanting to be a perfectionist.
Dave
Suggestion: coat the carve with a thin coat of 5 minute clear epoxy to seal the area being filled, use hot glue or silicon sealant to make a dam around the area being filled, overfill with resin the dam will prevent the resin leaking out. Then will cured flush cut the the area leaving enough for final sanding.
Works for me.
Ron
Ron
Crafers Crafts
Crafers Crafts
I don't understand why it didn't either. I have done quite a few epoxy inlays the past month and all have worked well. Like I said it isn't very noticeable, and it will do.
Dave
Dave
- scottp55
Thanks for the info Dave!
R.N.
R.N.
