Resin Inlay Cutting Board Hawks
- Aussie
- Model of CNC Machine: Robotics Model 8
Timber used:
American Walnut
European Birch
Blackwood
Cherry
V Carve:
Clearance: 1/8" EM
30 deg V Bit
DOC 7mm
American Walnut
European Birch
Blackwood
Cherry
V Carve:
Clearance: 1/8" EM
30 deg V Bit
DOC 7mm
Ron
Crafers Crafts
Crafers Crafts
- gkas
Re: Resin Inlay Cutting Board Hawks
Really nice work. You definitely have this figured out....
- Todd Bailey
- Vectric Staff
- Model of CNC Machine: CraftCNC
Look amazing!!!!
Yes, you do have that process worked out. Really looks great... well done and thanks for sharing!
Todd Bailey | Design and Make
DesignAndMake.com
DesignAndMake.com
- scottp55
Yep...definitely have a handle on that process Ron!!
Beautifully Done!
( I thought you said no more Blackwood frames?)
Beautifully Done!
R.N.
R.N.
- Aussie
Thank you.... never say never...
The frame is walnut.... Blackwood is used either side of the cherry.
Ron
Crafers Crafts
Crafers Crafts
- mtylerfl
Wonderful detail, Ron! Beautiful result!
- Model of CNC Machine: Camaster Stinger SR24
Beautiful...simply beautiful!!!
Joe
- mfirlott
- Model of CNC Machine: Stinger 1 (2014)
Well done Aussie. Another master piece!!!!
Where do all the cool logos come from? Are they local sports teams?
(Mitch)
CAMaster Stinger I
Vectric Aspire
Epilog 45watt Helix Laser
CAMaster Stinger I
Vectric Aspire
- scottp55
Thanks Ron!
NICE wood combos, and resin is......!!
Great work!
Great work!
R.N.
R.N.
- Model of CNC Machine: Probotix Meteor 25 x 50
That's a beautiful piece of work. Love the design and colors. I assume its for Looks only ,
Dave
Dave
- Model of CNC Machine: MechMate
Very nice work, excellent craftsmanship and love the colors.
- Aussie
Thank you all for your kind comments.
I expect the people I give these to will use them as a cutting board, it can always be resurfaced again to remove any cuts... I will be interested to see how well the resin holds up.
I should make my wife one so I can test the durability for myself.
Ron
Crafers Crafts
Crafers Crafts
Question on your epoxy work. How do you get such a nice shine? Do you wet sand or use a polish? I struggle to get both my epoxy & Corian surfaces to sparkle like yours does.
Joe
- Aussie
The finish is nothing special, I drum sand with 100 grit to remove the end mill tool marks after final flattening of the resin, then I use 120, 180 and 220 grits using a orbital sander.Holzarbeiter wrote: ↑Thu Sep 24, 2020 2:13 pmQuestion on your epoxy work. How do you get such a nice shine? Do you wet sand or use a polish? I struggle to get both my epoxy & Corian surfaces to sparkle like yours does.
The cutting board oil I use is Walrus food grade oil and gives a nice shine followed by Walrus wood wax.
I am very lazy when it comes to sanding and finishing.
Ron
Crafers Crafts
Crafers Crafts
Thanks for your replay, Aussie. The combo really makes the piece pop.
Joe
