One of my "to do" projects has been playing with the idea of routing silhouettes into note pads. I have also been using stencil fonts to cut names into the pads. To protect the top and bottom of the note pads while machining, I use two spoil boards. Here's the result of my research:
Here's a cheese, spoilboard sandwich that sort of shows how I do the procedure:
Bob
And, since I live in Wisconsin:
I like to machine the pads with the cardboard side up. This way the cardboard provides better support when using an up-cut bit. I cut a pocket of the object in the top spoil board, and use a profile cut for the pad. It speeds up the operation. So far, I have successfully done this with three pads stacked together at once.Routing note pads
- Bob Jr
- Model of CNC Machine: Axiom, Shark
Routing note pads
"Be accurate."
W. Tell
W. Tell
- WNC_Ed
- Model of CNC Machine: Shark HD4 AXYZ 4010
- Location: Western North Carolina - Heart of the Smokies
Re: Routing note pads
Bob, that is cool!
Great idea.
Thank you for sharing the "how to".
Adding this to the "projects to do" list.
Great idea.
Maker of sawdust
- highpockets
Bob, that's a great idea. What bit are you using?
Thanks for sharing....
- CrowsWW
- Model of CNC Machine: ShopSabre 4896
Bob,
Wow I never would have thought about do this. thanks for the directions.
Troy Crow
Crow's Woodwork's
I have a day job to support my wood habit!
Crow's Woodwork's
- Bob Jr
Thank you for the comments.
I used a 1/8" diameter upcut endmill. And, the same feeds and speeds I use for wood.
Bob
Bob
"Be accurate."
W. Tell
W. Tell
- jimandi5000
- Bob Jr
I look forward to seeing how these turn out if anyone tries this.
Bob
Bob
"Be accurate."
W. Tell
W. Tell
- Model of CNC Machine: Camaster Stinger SR24
That is just....so cool! What an ingenious idea. Thanks for sharing the details. I want to try this sometime (most likely after tax season).
Joe
