Valentine
Bob Jr
Model of CNC Machine: Axiom, Shark
Valentine
Post by Bob Jr »
I made this heart trivet for my wife last year...after Valentine's Day.
In case you're looking for a project in time for Valentine's day this year, here's the file.
heart trivet_1.crv
(970.5 KiB) Downloaded 100 times
Bob
hammer...nails...stuff
jimandi5000
Re: Valentine
Post by jimandi5000 »
Super nice work...
Jim
rtibbs2018
Model of CNC Machine: Shopbot desktop
Re: Valentine
Post by rtibbs2018 »
Very nice. Thanks for sharing your file
Re: Valentine
Post by highpockets »
Nice work Bob and thanks for sharing the file....
CrowsWW
Model of CNC Machine: ShopSabre 4896
Re: Valentine
Post by CrowsWW »
Thanks for the file Bob.
It looks great! Great Idea. I will make a couple for Valentine's day for my wife.
Troy Crow
Crow's Woodworks
I have a day job to support my wood habit!
scotttarnor
Model of CNC Machine: Pirnha LX
Re: Valentine
Post by scotttarnor »
Really nice! Thank you for sharing the file.
Scott T
Bob Jr
Re: Valentine
Post by Bob Jr »
You're all welcome.
Thank you for your comments.
Bob
jfederer
Model of CNC Machine: CanCam D23M
Re: Valentine
Post by jfederer »
Hi Bob, thanks for the file! I ran 3 copies this afternoon (slightly resized to use "oops" wood) for a matched set. I know my wife will love them!
Joe Federer
www.fabrikisto.com
www.federer.ca
Bob Jr
Re: Valentine
Post by Bob Jr »
WooHoo!!
Thank you for posting, Joe.
Bob
Holzarbeiter
Model of CNC Machine: Camaster Stinger SR24
Re: Valentine
Post by Holzarbeiter »
Very nice, Bob. Thanks for your generosity in sharing the file.
Joe
scotttarnor
Re: Valentine
I think I will try this design this weekend, One question what finish do you use that will stand up if my wife puts a hot pan on it ?
Thank You
Scott T
Scott T
Bob Jr
Re: Valentine
Post by Bob Jr »
Scott,
Since I have a cnc, I just figure that I'll make a replacement when a trivet wears out. As a result, I don't usually apply any finish. None of the trivets have been destroyed yet. I have tried a drying oil (like Watco) with no problem. I just don't know if it's necessary. We'll keep researching.
I think that I tried a salad bowl finish on the Valentine trivet when I made it a year ago. I can't give much of a report on that one though, because my Wife doesn't want to risk damaging it...
Bob
scotttarnor
Re: Valentine = long story Sorry in advance
Last night I decided to try making Bob's Trivet, It was a wake up for this new guy. I had a piece of cherry left over and figured I would use it to make a trivet for my wife. My board was a little narrower than the file Bob was generous enough to share, I thought no problem I will just resize it and cut away, Next I found I do not have an 1/8" end mill, no problem I have a 3/16", 1/16" can't make that big a difference....... Thankfully I stayed in the garage as the machine was working because on the last profile 2 cut as the bit was moving toward the Pocket cut heart I found out how much of a difference 1/16" can make, It snapped the heart out of the project....gottcha #1---Lesson learned.
Boy a loose piece of wood in a moving CNC makes a lot of noise! :oops:
So I remove every other profile2 cut and try to salvage my project so I have something for my wife on Valentines day, The first 2 cuts went great, 3 profile not so much, for some reason the right side of the cut was off the board on the top right of the heart, I must have screwed up the resize and it did not notice it in the preview. Resized again I start profile 3 cut and it stays on the board Yeah !
I then edited profile2 again to try and salvage the first piece.
Bob Thank You for sharing the project, Sorry I trashed your design with my amateur skills!
I learned a lot last night! #1 walk away if you are tired
#2 do not try and rush a project without checking every setting !
Scott T
Bob Jr
Re: Valentine
Post by Bob Jr »
Scott,
Nice job on your trivets. No trashing at all there. you have set a real nice example of creative cnc work. It's the problem solving part of working on a project, where the learning really happens!
Your words of advice are also very valuable.
Thank you for sharing your results.
Bob
scottp55
Re: Valentine
Post by scottp55 »
Scott,
You learned 2 important lessons...without injury :)
AND you wound up with 2 usable trivets with a little "Creative" sanding :)
I kinda like the bottom "Custom" cut style better! :)
GMH
