Whitetail Obsession Crib Board
Posted: Sat Aug 17, 2019 9:37 pm
Been working with solid surface material lately, Corian in this case. Deer hunting in November in Wisconsin
is a big deal. I decided to use the v-carve inlay methods to achieve what I wanted. Here I decided to use 4
differn't colors of corian to be inlayed into the cover of the cribbage board. The cover starts out as a 8x8 inch
piece that has a vcarve pocket of .2inch pocket with advanced toolpath and 1/8 inch endmill. The text, deer,
grass and log are put in differn't layers and machined in differn't colors at a start depth of .1 and a flat depth of
.1 inchs. What worked for me was to mirror the deer for instance, machine the the piece and glue into the cover blank
after it was dried cut it flush to the cover with a bandsaw, this will allow you room to glue the next color in
cover. Repeated the process for all the colors in the cover. Went back to the CNC put the cover back in the
alignment jig and ran a flatting toolpath with a .25 endmill until the cover blank was flat and flush and then
alot of wet sanding and buffing. I hope the post made sense, I tend to get ahead of myself.
