My first LED acrylic sign.
Dadof2and2
Model of CNC Machine: Fine Line Automation
Post by Dadof2and2 »
Actually my fourth sign. I had to mess up on three to get it right!
glenninvb
Re: My first LED acrylic sign.
Post by glenninvb »
Great job!
tonydude919
Model of CNC Machine: cnc mako shark ext bed with HD 5 gantry
Post by tonydude919 »
Great job on the acrylic. Nice crisp lines.
Tony
Came out ok in the end, just have to hope that the next job doesn't take as many tries :lol: :lol: :lol: :lol:
pops1964
Model of CNC Machine: shopbot buddy bt 32
Post by pops1964 »
Nice job DAD ,I just ordered my first shipment of acrylic to do my first sign trying to figure out V- bit or drag bit ? which did you go with ? And what settings did you use ? Thanks pops
POPS1964
SHOPBOT Buddy BT-32
Dadof2and2
pops1964 wrote:Nice job DAD ,I just ordered my first shipment of acrylic to do my first sign trying to figure out V- bit or drag bit ? which did you go with ? And what settings did you use ? Thanks pops
Hi Pops,
I used a 22.5 degree (45 degrees total) engraving bit set at a depth of .012" for this one. I set the speed up to 150" per minute and ran the router at about 18k RPM. I used an 1/8" up cut endmill for the cut out with tabs. That was set at about 12k RPM at 70" per minute.
The engraving had some melting of the acrylic but it did not seem to affect the way the sign lit up. If you can make sure your material is absolutely flat I suggest you engrave it at .008". I get my engraving bits from ebay (China). They are carbide and run only abou $1.20 each. I've had excellent results with them on oak and in my limited experience they seem ok on acrylic. I have a diamond drag bit ordered.
Rick
Trizoe
Model of CNC Machine: Hongda Boke HD-1325
Post by Trizoe »
Great result mate. I have only done a few test pieces so far but fill follow your settings and see if i get better results.
