Bird feeder
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Bird feeder
Post by glenninvb »
Whomever is responsible for posting and or creating the bird feeder .crv
Thank you, I did a see-thru version with 1/8" cast acrylic (had to heat form)
thank you and the chickadee's and finches thank you as well :D
sawman
Model of CNC Machine: Shark Pro
Re: Bird feeder
Post by sawman »
Hi
I was wondering if I could get a copy of the files I left a message on the other site but no response it has been so time
I would like to make a new feeder I am just asking thanks using 7.5 and 6.5 Vcarve
sawman@meltel.net
dond52
Re: Bird feeder
Post by dond52 »
Sawman, I believe the files are available at this thread. http://forum.vectric.com/viewtopic.php? ... 45#p116330 I was just thinking as I was reviewing the project. It would make a dandy use of plastic 2 liter soda bottles.
glenninvb
Re: Bird feeder
Post by glenninvb »
Sawman,
Here is CRV.
Machine the vector for the top and bottom panels (profile, on-line) with bit dia. to fit material used. I used 1/8" acrylic so used an 1/8 bit.
You can size the dowel holes as you prefer as well.
feeder.crv
(218 KiB) Downloaded 290 times
