Reversed V-Carving
Reversed V-Carving
Last night I had trouble sleeping. I don't know why but an idea for doing reverse V-Carving with VCW ran through my head. I had never really thought about this before. Anyway here's a screen shot of what the result of my sleepless night produced. Am I the only one who dreams in CAD?
- (53.01 KiB) Downloaded 587 times
- Paco
This refer to prism or raised edge strategie and named bevel carving too.
This one is particular since it has it's inside corners sharpen. Most routing CAD/CAM package only do "profiling" (or machine along vector) pass with a V tool bit (which doesn't sharpen inside corners). "Basic" raised edge can be achieve pretty easily. To get inside corners sharpen that way, one has to figure a techinc of it's own. I got one, what is yours Phil?:roll:
Now, can you make the difference between intanglio and raised edge strategie?!
Sharp inside corners
Paco,
the drawing for the star is made up of four closed vectors. Each one is sort of an L shape. V-Carving with a 90 degree V-Bit cleans up the inside corners. What's your method?
Isometric view
Paco,
I think you're right. I didn't realize that I didn't have what I thought until I rotated the view.
- (41.96 KiB) Downloaded 367 times
- Paco
Well, yeah, it's different but still intersting I believe. There might be some interesting applications...?!
I have'nt worked hard on this, but "detailed raised edged" stars are'nt so easy... not with the current options there is with CAD/CAM packages available. It would require some custom 3D moves for thoses inside details.
