Scroll Saw storage box
lockeyone
Model of CNC Machine: other software 50-50 router, Mach3, Epilog 60W
Post by lockeyone »
Here is a project I did today. It is made out of a wood core commercial door material. I have some old doors the were replaced from a remodel. The scroll saw is something I occasionally need in my job on site and it gets abused. So, I wore out my last one and a friend was going to toss this one out so I took it. This replacement saw wouldn't fit in the toolbox I used to use so I decided to build one. The box was drawn in other software and the dxf imported in VCarve. The box looked so nice I decided to put my logo on it and I'll be sure to display it while working on site. The handle is a door pull removed from somewhere (I can't seem to throw anything out). The hinges are from the standard size doors. The latch is a window lock. The only problem with making projects with this door material is there are gaps in the inner wood core. I tried some filler materials and it is ok but not the same as having solid/tight wood. Really has nice veneer on it. To think this was saved from the dumpster.
My son stopped by while I was doing the logo and I told him I added the date for the benifit of the kids. So when they are dividing up my estate they have a clue what I was doing on 5/07.
Now I have proof for the IRS that I bought this for my business.
If you want to kill time, why not work it to death!
HayTay
Post by HayTay »
Lockeyone,
WOW, I am impressed. Very nicely done, and all from recycled cast-offs to boot.
BTW, isn't that power tool officially classified as a "jig saw" rather than a scroll saw?
Either way excellent work,
HayTay
Don't be the one that stands in the way of your own success!
lockeyone
Post by lockeyone »
Well, maybe, the blade does turn on this that is why I called it a scroll.
Wemme
Post by Wemme »
Nice Box, artwork on the front is impressive.
Regards
Bart
Jeff Guinn
Post by Jeff Guinn »
Great job! The vcarving & painting is really clean & crisp. Can you tell us what type of paint mask you used? Thanks for posting the photos.
Jeff
lockeyone
Post by lockeyone »
The paint masking it the basic stuff from 3M and I bought it off ebay, partial roll. I did have a little bleed and I used a soft rag and mineral spirits to lighty clean up some edges. I clear coated everything before the colors were sprayed on with cheap paint from the local hardware store.
DavidCousins
Post by DavidCousins »
Nice work. Everything from the use of scrap materials, the design, and the personnalized touch of the script.
Dave
lpcsales
Post by lpcsales »
Wow! That was one 'professional' job! :P
Good work and I especially like the front of the case. Very well done. Your case has made a 'fine' home for the throw away! :)
Dave
Epilog 24TT 40w and Legend 36EXT 75w Laser Engravers, Roland SP-300V, BabyLoc PR600 Embroidery Machine, Panther 24" Vinyl Cutter, Mighty Presses (hat & T-Shirt), PRT48 Router
Greasetattoo
Post by Greasetattoo »
Very well done!
Excellent Job!
