Bird feeding season is coming
mrmfwilson
Model of CNC Machine: Legacy Arty 36
Re: Bird feeding season is coming
Post by mrmfwilson »
I would like a copy also. mr-wilson@austin.r.com Why not just attach the files to the post? Seems like that would make it easier on you.
Mr. Wilson
CenterLine Designs
Facebook - Centerline Designs
Bishop01
Model of CNC Machine: cnc
Post by Bishop01 »
With SeKa's permission I have attached my version of his bird house. I changed job setup to inches and increased the material thickness to 0.5 inches. Then I shrunk the dimension to fit in a 12" x 12" square and used a profiling tool path instead of a pocketing one for the roof and seed holder. With all of these slight changes I can run the entire program with a single 0.25 inch cutter. I planned on making mine out of solid surface material, but the first one I cut slipped in the machine, I will try running one again this weekend after I built a better fixture.
Seka, thanks again for the file this is a great project.
Bird Feeder2.crv3d
(882.5 KiB) Downloaded 397 times
mrmfwilson
Bishop01,
Can you extract some dxf or eps files for those of us that only have V-Carve pro?
Mike
Mr. Wilson
CenterLine Designs
SekA
Post by SekA »
Dear mrmfwilson:
on Jan the 25th I have tried several times to send you files but your mail was not available.
Attached is the message that I received:
+++Start of Quote:+++
This Message was undeliverable due to the following reason:
Your message was not delivered because the destination computer was
not found. Carefully check that it was spelled correctly and try
sending it again if there were any mistakes.
It is also possible that a network problem caused this situation,
so if you are sure the address is correct you might want to try to
send it again. If the problem continues, contact your friendly
system administrator.
Host austin.X.XXXXXX not found ( X.XXXXX stands there to protect you).
The following recipients did not receive this message:
+++End of quote+++
I have sent files to all forum readers that requested them. Many confirmed the receipt.
Two readers E-mails have shown the same problem.
I am sorry for that.
Regards
Aleksander
Bishop01
Post by Bishop01 »
mrmfwilson,
Attached is a DXF for the V-carve users.
Bird Feeder2.dxf
(332.49 KiB) Downloaded 465 times
mrmfwilson
Bishop01 wrote:mrmfwilson,
Thanks!
Mr. Wilson
CenterLine Designs
JoeSmithies
Model of CNC Machine: shark
Post by JoeSmithies »
I was wondering if you still have the code for this Bird house and still share the code my existing one has 10" of snow in it thanks you in advance, Joe. jsmithies@ymail.com
davemartin88
Model of CNC Machine: CAMMaster Stinger II
Post by davemartin88 »
Thanks so much for this project, I downloaded the modified file and it looks like it will work for me. I really like the modern look and will give it a try. I'm new to CNC but looks like a really useful project and perfect valentine gift for my wife!
donnie
Model of CNC Machine: shopbot buddy
Post by donnie »
Job very well done.
I would love to have a file on this.
dpw2@comcast.net
iank
Model of CNC Machine: CNCDudez Mini Muscle
Post by iank »
Thanks for the DXF
sawman
Model of CNC Machine: Shark Pro
Post by sawman »
Hi
I was wondering if I could get a copy of the bird house plans my boss was a 30 year Navy and got me started watching birds now I blame him for all my expense but it is very cool to just sit on the deck and watch
I am using VC 7.0 if i could get a copy and parts list thanks
sawman@meltel.net
Michael
