Beard Comb
- Model of CNC Machine: Legacy Arty 36
Beard Comb
I made 32 of these for the Bearded Savant here in Austin. I made two versions. A Texas Redbud handle with a spalted Pecan comb and another with spalted Pecan handle and a Ipe comb. Fun project. I started with a picture of a comb that they were having made by hand. I used the picture to scale the comb and trace the outline. I used the molding tool path for the rounding of the handle and the fluting tool path for the comb angle and cutting the tines. The logo is cut with a 1/32” ball nose. It is a four step process. First I cut the comb insert blanks. Then I cut the comb insert hole out of the blanks I will use to cut the final combs from. I then glue the insert into the blanks. Then I am ready to put the blanks on the CNC and cut out both sides. That may be five steps. They love them!!
Mr. Wilson
CenterLine Designs
Facebook - Centerline Designs
CenterLine Designs
- scotttarnor
- Model of CNC Machine: Sienci Long Mill
Re: Beard Comb
They look great! Just curious, do you do the comb "teeth" as a separate insert to get the grain direction running along the teeth and opposite to the grain direction of the comb "handle"?
Re: Beard Comb
Yes that is correct. The teeth are stronger when cut with the grain. I can also use smaller pieces, width wise, of wood by making them this way.
Mr. Wilson
CenterLine Designs
CenterLine Designs
