Easy Box Maker 3.4 Small Text in config window
sharkcutup
Re: Easy Box Maker 3.4 Small Text in config window
Post by sharkcutup »
rwebcon wrote:
Mon Nov 11, 2024 2:48 am
Loaded 3.6 and set to 220 and restarted. Looks great!!!!!
Thanks a bunch, its really nice Gadget!!
THANKS again...
:D
Awesome! It is good to see that you are up and running with the Gadget.
Any questions and/or comments feel free to drop a line or two here on the Vevtric Forum We are bound to see it.
Cheers,
Sharkcutup
V-Carve Pro 12.013
rwebcon
Model of CNC Machine: Axiom Elite 4 X 4
Post by rwebcon »
Quit question. Let’s say I have 3 or 4 box settings I work with on a regular basis. Is there any way to save each Box settings so I do not have to keep entering the settings for each box every time I want to make a box?
rwebcon
Post by rwebcon »
Version: Not getting and tool paths created. I did not check this before......
jimandi5000
Post by jimandi5000 »
rwebcon wrote:
Mon Nov 11, 2024 8:39 pm
What version are you running?
Jim
rwebcon
Post by rwebcon »
The new 3.6. You just released it yesterday...
rwebcon
Post by rwebcon »
For some reason my default tool list was not saved.... It seems to be working
Very sorry for the inconvenience.
sharkcutup
rwebcon wrote:
Mon Nov 11, 2024 8:30 pm
Well when you get the hang of using the Gadget Try out the Import Feature of the Gadget. The Gadget saves an Export file to your computer with all the settings of any box you create. You can import that file with the same settings as a box in which you had previously created with the Export file. You can also write your Save Path accordingly to match the different boxes you create thereby making it easier to Identify which box is which.
Just Some Thoughts to Pass Along!
Sharkcutup
V-Carve Pro 12.013
jimandi5000
Yes, Sharkcutup is correct. You can have standard setups. The gadget creates a settings file in the Project Folder that holds all of the setting you have entered. I would set the gadget up per the box you want to make. After completing the setting and you have created the drawing. Look in the Project Folder and name the file with ".EXPORT" extension and name the file as per the box size with the ".EXPORT" extension. after completing this process for all of the standard boxes, you can use the Import button the reload the standard items.
I hope this helps.
Jim
rwebcon
Post by rwebcon »
Yes, it does thanks for the input.
rwebcon
Post by rwebcon »
Trying to import setting for a box but getting an error on the import. Any Ideas on why?
See attachment for dertails.
adze_cnc
Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
Post by adze_cnc »
While I don't know why that's happening something to note for the gadget writer:
Note that the path in the first image is different than the path in the error message.
rwebcon
Post by rwebcon »
Just to see if loading from OneDrive was a problem, I moved it and got same results.
jimandi5000
rwebcon wrote:
Wed Nov 13, 2024 12:18 am
I see a extra ")" in the code. I will post a fix ASAP.
Jim
sharkcutup
My copy of 3.6 Version works fine on Importing ----
That 26 represents the line number of the saved file Item at that location. I have run into this before myself.
Can you post a copy of the file (Test Box-202411121428)? So I can see what you have for Line 26. I know that the LINE numbers are not noted in the file but --- this is the case. And in that instance it was something I had added when using the gadget that the gadget does not like when importing. I believe at that time it was certain Characters entered it would not import.
Sharkcutup
V-Carve Pro 12.013
rwebcon
Post by rwebcon »
Here is my copy. Had to change file extension to attach file. Did not like Export????
Test Box-202411121428.txt
(5.16 KiB) Downloaded 26 times
