Box creator LUA error (with screenshot)
- Model of CNC Machine: LongMill
I just upgraded to “Pro” mainly because of Gadgets.
Right away I created a project and installed and started the Box Creator gadget.
I got the following screen
Re: Box creator LUA error (with screenshot)
Where did you download the gadget from? That error usually occurs because you've downloaded the wrong version of the gadget for the version of Cut2D/VCarve/Aspire you're using.
For v12 you need this one - https://gadgets.vectric.com/V12/box_creator
I downloaded and installed the software using the links on the Vectric website.
I would have deleted the install and tried again but I don’t see a provision for deleted an installed gadget.
You don't need to delete it. Installing a new version will overwrite the other.
The user interface is displayed and I can make selections.
I get the error when I click on “OK” AND when I leave the gadget by clicking “Cancel”.
If I leave without clicking “OK”, I don’t get any error.
I also don’t get the error when I just close the gadget window.
I reinstalled… no change.
I’m running VCarve Pro 12.010
Oh ok, when you said you were getting the error straightaway I assume you meant as you soon as you clicked on the gadget in the menu.
Have you selected a tool? Without a tool selected you will probably get that error.
Thank you. I hadn’t selected a tool.
I think an error message that said “No tool selected” might have been more appropriate, but now I know.
I appreciate the help.
Where do we report “bugs” and request enhancements for Box Gadget?
- sharkcutup
Box Creator Gadget
Try this one!
Change the .zip to .vgadget then install
Sharkcutup
Try this one!
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
I'll try again tomorrow.
- Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
That doesn’t quite answer the question. There are four links on the Vectric site that could have been used:
Also, if the gadget gives you a default setting for a box to start with then use it as a test of its installation. Don’t spend time and effort trying to create one of your own.
Get used to the tool first and then apply it.
- sharkcutup
If this is the Gadget I will post a video soon on my Youtube Channel showing how to use it.
But I will tell you this too there is another Box Gadget called Easy Box Maker created by jimandi gadgets which has more features that can be downloaded from jimandi.com
Sharkcutup
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- sharkcutup
Forgot to post image of supposed gadget ---
Just making sure we are on the same page
Sharkcutup
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
