position of tabs must already have been defined on vectors
jimandi5000
Post by jimandi5000 »
Hello all,
I have a question to the bright minds of the bunch.
Do you know how to define the position of tabs on a vector?
On page 124 of the Gadget API document has the following:
-- true to use tabs (position of tabs must already have been defined on vectors)
profile_data.UseTabs = false
-- length for tabs if being used
profile_data.TabLength = 5.0
-- Thickness for tabs if being used
profile_data.TabThickness = 1.0
-- if true then create 3d tabs else 2d tabs
profile_data.Use3dTabs = true
As always thanks for any help.
Jim
adze_cnc
Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
Re: position of tabs must already have been defined on vectors
Post by adze_cnc »
Hello Jim,
From the SDK pdf dated 18th October 2021 (pages should be close no matter which PDF you use) some pages of interest:
p.62 under CadContour we get ":InsertToolpathAtTabAtPoint()"
p 94 ToolpathTab object: interestingly, this mentions the method "InsertToolpathTabAtPoint" rather than the spelling on p. 62
Steven
jimandi5000
adze_cnc wrote:
Mon Aug 19, 2024 10:19 pm
Hello Jim,
Steven
Thanks Steven!
Jim
jimandi5000
Hello Jim,
Steven
Hi Steven,
I hope you are doing well. I have you been able to insert Toolpath Tabs with InsertToolpathTabAtPoint ?
is you would like to take this offline use jim@jimandi.com
Jim
