I receive an error when I try to delete a tool I believe.
Thanks!
Error deleting tool.
- Model of CNC Machine: EZ Route 4x8/WinCNC
- jimandi5000
Re: Error deleting tool.
Hi Bill,
I will look into this and see if I can reproduce the issue and add an error trap to manage the issue.
Can you send me the EXPORT file for this drawing?
Jim@JimAndI.com
Jim
Jim
- sharkcutup
Tool Clear3 seems to be working okay on my copy of the code BUT
I am finding that the Last Tool Clear Button (7th Tool) posts an error message similar to the OP's post.
Jim you may want to add this below to the Dialog File. It is not there ---
Function OnLuaButton_FunctionClear7(Pdialog) -- Tool clear 7
Pdialog:UpdateLabelField("DialogWindow.Alert", "")
MillTool7.Name = "No Tool Selected"
Pdialog:UpdateLabelField("ToolNameLabel7", MillTool7.Name)
RegistryWrite()
return true
end -- function end
Added the above to my copy and now that clear button woks fine.
Sharkcutup
RegistryWrite()
return true
end -- function end
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- jimandi5000
Thanks.sharkcutup wrote: ↑Fri Jun 14, 2024 4:07 amTool Clear3 seems to be working okay on my copy of the code BUT
RegistryWrite()
return true
end -- function end
Sharkcutup
Jim
Jim
- sharkcutup
Same Dialog File ---
line 3160 --- </tr> from
remove the word -- from
Not exactly sure why that is there but I believe it is not needed.
Sharkcutup
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
Jim:
function InquiryWallOrBase at line 94 needs changing to the following as it refers to both tool 7 and tool 6:
Code: Select all
if dialog:GetTool("ToolChooseButton7") then
MillTool7 = dialog:GetTool("ToolChooseButton7") -- ???? comment wrong but I don't know what is right ???
end
I wonder if those seven OnLuaButton_FunctionClear<n> functions could be replaced with:
Note: I haven't actually tested the code but it should work (famous last words).
Code: Select all
function clearMillToolFromDialog(Pdialog, toolNumber)
local function createToolArray()
local MillTools= {MillTool1, MillTool2, MillTool3,
MillTool4, MillTool5, MillTool6, MillTool7
return MillTools
end
local function updateDialogAndRegistry(toolNumber, toolName)
Pdialog:UpdateLabelField("ToolNameLabel" .. tostring(toolNumber), toolName)
RegistryWrite()
end
if toolNumber == nil then return false end
local MillTools = createToolArray()
local millTool = MillTools[toolNumber]
millTool.Name = "No Tool Selected"
updateDialogAndRegistry(toolNumber, millTool.Name)
end
function OnLuaButton_FunctionClear1(Pdialog)
clearMillToolFromDialog(Pdialog, 1)
return true
end
function OnLuaButton_FunctionClear2(Pdialog)
clearMillToolFromDialog(Pdialog, 2)
return true
end
function OnLuaButton_FunctionClear3(Pdialog)
clearMillToolFromDialog(Pdialog, 3)
return true
end
function OnLuaButton_FunctionClear4(Pdialog)
clearMillToolFromDialog(Pdialog, 4)
return true
end
function OnLuaButton_FunctionClear5(Pdialog)
clearMillToolFromDialog(Pdialog, 5)
return true
end
function OnLuaButton_FunctionClear6(Pdialog)
clearMillToolFromDialog(Pdialog, 6)
return true
end
function OnLuaButton_FunctionClear7(Pdialog)
clearMillToolFromDialog(Pdialog, 7)
return true
end
- jimandi5000
