Error deleting tool.
dyn0bill
Model of CNC Machine: EZ Route 4x8/WinCNC
Post by dyn0bill »
I receive an error when I try to delete a tool I believe.
Thanks!
jimandi5000
Re: Error deleting tool.
Post by jimandi5000 »
dyn0bill wrote:
Thu Jun 13, 2024 11:28 pm
Thanks!
Hi Bill,
I will look into this and see if I can reproduce the issue and add an error trap to manage the issue.
Can you send me the EXPORT file for this drawing?
Jim@JimAndI.com
Jim
sharkcutup
Post by sharkcutup »
Tool Clear3 seems to be working okay on my copy of the code BUT
I am finding that the Last Tool Clear Button (7th Tool) posts an error message similar to the OP's post.
Jim you may want to add this below to the Dialog File. It is not there ---
Function OnLuaButton_FunctionClear7(Pdialog) -- Tool clear 7
Pdialog:UpdateLabelField("DialogWindow.Alert", "")
MillTool7.Name = "No Tool Selected"
Pdialog:UpdateLabelField("ToolNameLabel7", MillTool7.Name)
RegistryWrite()
return true
end -- function end
Added the above to my copy and now that clear button woks fine.
Sharkcutup
V-Carve Pro 12.013
jimandi5000
sharkcutup wrote:
Fri Jun 14, 2024 4:07 am
RegistryWrite()
return true
end -- function end
Sharkcutup
Thanks.
Jim
sharkcutup
Same Dialog File ---
line 3160 --- </tr> from
remove the word -- from
Not exactly sure why that is there but I believe it is not needed.
Sharkcutup
V-Carve Pro 12.013
Post by adze_cnc »
Jim:
function InquiryWallOrBase at line 94 needs changing to the following as it refers to both tool 7 and tool 6:
Code: Select all
    if dialog:GetTool("ToolChooseButton7") then
      MillTool7 = dialog:GetTool("ToolChooseButton7")  -- ???? comment wrong but I don't know what is right ???
    end
Post by adze_cnc »
I wonder if those seven OnLuaButton_FunctionClear<n> functions could be replaced with:
Code: Select all
function clearMillToolFromDialog(Pdialog, toolNumber)
  local function createToolArray()
    local MillTools= {MillTool1, MillTool2, MillTool3,
                      MillTool4, MillTool5, MillTool6, MillTool7
    return MillTools
  end
  local function updateDialogAndRegistry(toolNumber, toolName)
    Pdialog:UpdateLabelField("ToolNameLabel" .. tostring(toolNumber), toolName)
    RegistryWrite()
  end
  if toolNumber == nil then return false end
  local MillTools = createToolArray()
  local millTool = MillTools[toolNumber]
  millTool.Name = "No Tool Selected"
  updateDialogAndRegistry(toolNumber, millTool.Name)
end
function OnLuaButton_FunctionClear1(Pdialog)
  clearMillToolFromDialog(Pdialog, 1)
  return true
end
function OnLuaButton_FunctionClear2(Pdialog)
  clearMillToolFromDialog(Pdialog, 2)
  return true
end
function OnLuaButton_FunctionClear3(Pdialog)
  clearMillToolFromDialog(Pdialog, 3)
  return true
end
function OnLuaButton_FunctionClear4(Pdialog)
  clearMillToolFromDialog(Pdialog, 4)
  return true
end
function OnLuaButton_FunctionClear5(Pdialog)
  clearMillToolFromDialog(Pdialog, 5)
  return true
end
function OnLuaButton_FunctionClear6(Pdialog)
  clearMillToolFromDialog(Pdialog, 6)
  return true
end
function OnLuaButton_FunctionClear7(Pdialog)
  clearMillToolFromDialog(Pdialog, 7)
  return true
end
Note: I haven't actually tested the code but it should work (famous last words).
jimandi5000
Yep, that would reduce the code stack.
Jim
