Is the Box Creator Gadget...
NewAtThis
Model of CNC Machine: Stepcraft M.1000
Post by NewAtThis »
...available in metric measurements, please?
Or is it a setting somewhere in VCarve Pro.
Be wary of taking the advice of someone who thinks he knows what he's doing, and don't listen to me!
Re: Is the Box Creator Gadget...
It works in whatever units you've created the job in.
From memory that gadget doesn't like you using imperial tools in a metric job though.
sharkcutup
Post by sharkcutup »
Top
Job Setup change Units from inches to mm then click okay.
Then use Box Creator Gadget with metric numbers.
Ahhhh, Adrian beat me to it with an interesting point I was not aware of.
Sharkcutup
V-Carve Pro 12.013
NewAtThis
Post by NewAtThis »
Well, that wasn't particularly intuitive in the software, but thank you.
The job setup in in metric but the sizing in the Gadget appeared to be in inches (i.e. 24 x 16 x 14), so I guess I made an assumption.
Maybe because it's Sunday morning... :D :lol:
Thank you, gentlemen.
It displays whatever the last used values were. If you're using it for the first time those numbers are the default. Most users are American.
sharkcutup
Assumptions can be problematic in their own nature. It never hurts to try first before having to make an assumption/conclusion.
Yeah, Sundat Morning and probably have not had that first cup of coffee yet!
Sharkcutup
V-Carve Pro 12.013
