Turned profile gadget
TOMMYD
Model of CNC Machine: HOME MADE
Post by TOMMYD »
Is there a tutorial for the gadget TURNED PROFILE with v carve pro 11?
Re: TURNED PROFILE GADGET
Post by Rcnewcomb »
Consider using the moulding toolpath instead of a gadget.
TOMMYD
Post by TOMMYD »
thanks for your help. i don't know why i didn't see that video. I will check out using the moulding toolpath
TOMMYD
Post by TOMMYD »
Rcnewcomb wrote:
Wed Mar 22, 2023 4:48 pm
Are there any tutorials on using the moulding toolpath with a rotary axis?
Re: Turned profile gadget
Post by Rcnewcomb »
Create a rotary project, 26 inches long with a diameter of 4 inches.
Create a vector that starts and 0,0 and ends at 0,12.5664, i.e the circumference of the blank. This will be the drive rail for the moulding toolpath.
On the Clipart tab select Rotary Profiles and drag Baluster_1 onto your project.
Click on the drive rail created in step two. This selects it. (It should be pink if selected).
Press <F12> to go to the toolpaths section.
Click on the moulding toolpath icon
With the drive rail already selected do a <Shift>Click to select the baluster profile. It should look like this:
Click Calculate.
Click Preview All Toolpaths
TOMMYD
Post by TOMMYD »
Thanks Randall, I will give this a try. Tommy
mtate
Model of CNC Machine: Shark HD520
Post by mtate »
Randall,
I have never run a rotary project on my cnc yet. I'm setting up the vcarve file right now as in your steps above. When I go to save the toolpath I'm assuming I should be using the Next Wave-Rotary Along X - Wrap Y inch and not the Next Wave CNC inch post processor? Or does it know to use the rotary post processor as the job was setup as a rotary?
Post by Rcnewcomb »
Yes, you must use a rotary post-processor.
I've defined two different machines in VCarve. One for flat work, and the other machine for rotary work. I set up the rotary machine to use the wrapped post processor by default.
