Vertical dovetails
- Model of CNC Machine: Shark HD3
Vertical dovetails
Is there a vertical dovetail gadget? I would like to make a dovetail box using a dovetail bit.
- jimandi5000
Re: Vertical dovetails
Here you go...
- EasyDovetailMaker.zip
- Rename to: EasyDovetailMaker.vgadget
- (2.4 MiB) Downloaded 159 times
Jim
Jim
Jim
Thank you that definitely looks like what I am looking for in a gadget.
Harvey
Harvey
Fantastic PDF, I wish all gadgets had this.
Just downloaded Pro version and First gadget I am trying. I am having trouble installing the gadget. Any help will be appriceated.
Darren
Darren
Because the forum software doesn't allow attachments with ".vgadget" extension the file is uploaded as "EasyDovetailMaker.zip". Rename this to "EasyDovetailMaker.vgadget" after downloading and before installing. Do not extract the ZIP file if you want the Vectric software to automatically install the gadget.
To install the gadget into Aspire/VCarve Pro choose on of the following methods:
- with Aspire/VCarve closed you can "double-click" on the .vgadget file in Windows Explorer to automatically load Aspire/VCarve and install the gadget.
- if you already have Aspire/VCarve open you can install the gadget by using the menu option: Gadgets > Install New Gadget...
