Box Gadget To Work with VCarve Pro 11
The current box gadget works with VCarve Pro 10.5 but apparently not with11.003. Will a box gadget be made available to work with Ver. 11?
- jimandi5000
Re: Box Gadget To Work with VCarve Pro 11
Are you running the correct version? A common problem is that people use a Google search to find the downloads and end up downloading a gadget for a different version from one of the web pages setup for earlier versions.
All version 10 gadgets work fine with version 11.
The correct download location for version 10 gadgets is the default gadgets site which is - https://gadgets.vectric.com/ - and then click on "Access Gadget Library".
A direct download link to the Box Gadget is - https://gadgets.vectric.com/V10/box_creator.html
Another issue that I've seen is people running the gadget and not selecting a tool before hitting OK which does give an unhandled error. Selecting a tool prevents that.
You are correct. Got it to work. Operator error.
Thank you,
Thank you,
