Getting Started with Lua
unicacher
Model of CNC Machine: ShopBot Desktop
Post by unicacher »
Once upon a time, I was a fairly proficient code writer--- like 20 years ago. Between time and changes in syntax and structure, the gears are getting stuck.
Could I get a nudge forward? Given this code as a base, how do I return the number of objects on the selected layer? Currently, I get "no static 'CadLayer' in class 'CadLayerManager'". I've tried several combinations of this property structure with the same results.
Code: Select all
-- VECTRIC LUA SCRIPT
function main()
	job = VectricJob()
	layer = job.LayerManager:GetActiveLayer()
	objects = CadLayerManager.CadLayer.Count
	MessageBox ("objects=" .. objects)
	return true
end
I think once I see the correct structure of the properties, it'll make sense.
Re: Getting Started with Lua
Have a look at the Layer_Example script in the SDK. That has a function that counts objects on a layer.
