I'm trying to install the Dogbone gadget into VCarve Pro 10.512 on Windows 10 running under Parallels on a Macbook Pro. I download the installer and run it and it gets to the part where it lists what components to install... and there's nothing listed (see attachment). When I finish out the installer wizard, of course, the Dogbone gadget is not in the Gadgets menu.
Anybody have an idea how I can get this gadget installed? I really need it. I can't imagine having to hand draw all those dogbone fillets.
Dogbone gadget won't install
- Model of CNC Machine: custom
Re: Dogbone gadget won't install
Can you not use the fillet tool under edit objects?
If you are running a .EXE file then it’s for 9.x and below:
https://gadgets.vectric.com/V10/dogbone.html
is for v10.x
Fillet tool is good if you only have a handful to create.
is for v10.x
Good point. I definitely can for small projects. It just becomes really tedious on large jobs with dozens of parts. I do a lot of jobs with mortise & tenon joints, box joints and tab & slot joints. I'm not super excited about having to manually apply dogbones on every interior corner.
You are a legend. That was the problem. My Google search took me to an older dogbone gadget page.
A thousand thanks!!
A thousand thanks!!
adze_cnc wrote: ↑Sat Apr 03, 2021 10:11 pmIf you are running a .EXE file then it’s for 9.x and below:
is for v10.x
Funny, whenever I search for a gadget for my v9.5 install I keep get v10.x ones...
