LUA command for fillet on 2d square
Ysebarth
Model of CNC Machine: Stepcraft
Post by Ysebarth »
I'm just starting to learn how to work with LUA scripting to create gadgets or make live easier when repeating steps on different dimensions. I might have the wrong way of aproaching this, but the question is: how can I apply a fillet (corner radius) to a dimensioned square?
I like to create a square, which is i.e. a simply cut board, by giving the dimension through LUA script. So imagine I define a board with 300x250mm. How can I apply fillets (corner radius) to this square, meaning that the cut toolpath shall have a radius of r5 instead of cutting sharp edges?
Wasn't able to find any command that seems to do this.
Looking forward to your replies.
ThX
Re: LUA command for fillet on 2d square
There isn't a one to one relationship between tools available in the UI and tools in the LUA library so sometimes you have to write the routine or try a different approach like offsetting/insetting. Look at this gadget for code ideas - viewtopic.php?f=47&t=27848
adze_cnc
Post by adze_cnc »
Rather than thinking I need to fillet a rectangle how about thinking I need to create a rectangle with rounded corners? I haven’t looked at the API in a long time. Is there an API call to create a rectangle with rounded corners?
