In the gadget box creator using the Square Tabs.
If I want a box with an inside dimension of 8x 10 then what do I need to add to get that after it has been cut out.
Using.25 Baltic Birch plywood and .125 EM
Thanks Jeff
Size of a box
Re: Size of a box
.5" (thickness of material x2) to both measurements should get you an 8" x 10" inside measured box using Square Tabs.
I always use a tolerance of .01 but of course that is for my machine
Sharkcutup
Sharkcutup
www.hoganscnccrafts.com
One on One V-Carve Help is Available!!!
PM me for details!
V-Carve 10.512
PM me for details!
V-Carve 10.512
- Model of CNC Machine: Shapeoko 3D XXL
Re: Size of a box
My next question is this I have tried everything I can think of to be able to move the parts around to get them set up so they don't a lot of wood.. When I try to move and rotate the parts the cut line does not move with it.
Jeff
Jeff
Re: Size of a box
Jeff
Jeff
- Model of CNC Machine: Openbuilds Ox
Re: Size of a box
Did you recalculate the tool paths after moving the parts?
Re: Size of a box
I always group the vectors before moving then ungroup them after once satisfied with placement/location I then recalculate toolpaths. By Grouping the Vectors it keeps them all together when moving.cusoak wrote:
Jeff
Sharkcutup
PM me for details!
V-Carve 10.512
PM me for details!
V-Carve 10.512
Re: Size of a box
Thanks for the reply
Jeff
Jeff
