display layer menu in html?
Chelmite
Model of CNC Machine: Legacy Maverick 4x8, BOSS laser
Post by Chelmite »
How do I display a menu with all the layers in the design?
I can get a list of the layers with the following, but how do I get that into the HTML?
Code: Select all
   local job = VectricJob()
   if not job.Exists then
  	 DisplayMessageBox("No job loaded")
   	return false;
   end
   local active_layer = job.LayerManager:GetActiveLayer()
   local layer
   local layers={}
   local pos = layer_manager:GetHeadPosition()
   while pos ~= nil do
   	layer, pos = layer_manager:GetNext(pos)
   	layers[#layers+1] = layer
   	printf("%s", layer.Name)
   end
Re: display layer menu in html?
Depends how you want to display it. It's all HTML rather than Lua. You could build and HTML table, create a dropdown or a large list/edit box. Look up how you would do it for a web site and just build the same code in a Lua variable and display it with the HTML commands in the SDK.
