Error on Box Creator gadget
hmatyas
Model of CNC Machine: Shark HD3
Post by hmatyas »
Hi
I got this error and I'm not sure how to fix it.
Error is line 1702 AddToolPicker: No matching overload found
Thanks in advance.
Harvey
gregk
Vectric Staff
Model of CNC Machine: None
Re: Error on Box Creator gadget
Post by gregk »
Hi Harvey,
Most likely you've downloaded the gadget for older version. Please use this link for V10:
http://gadgets.vectric.com/V10/box_creator.html
Greg K
hmatyas
Post by hmatyas »
Greg
Thank you it now works. :D
Are there any other gadgets that need to be updated for Version 10 of Vcarve?
Harvey
Any gadget that allows you to select a tool will need to be re-installed. It's often best to always install the gadgets from the correct version website rather than copying them over to be on the safe side.
hmatyas
Post by hmatyas »
Thank you, I did not notice that there is a version 10 on the link that I went to install the box creator gadget.
Tonight, I will reinstall all the gadgets from the correct version.
Harvey
