Can't get dovetail toolpath creator to work
George B.
Model of CNC Machine: shotbot desktop
Post by George B. »
]have used dovetail pin creator gadget successfully but then can not get the dovetail toolpath creator to work. Aspire 10. below are test file used and error returned.
DovetailGadgetTest.crv3d
(27 KiB) Downloaded 17 times
Re: Can't get dovetail toolpath creator to work
Are you using the correct version of the gadget? That's an error I would expect to see if a v9 gadget was used in v10.
A v10 version can be downloaded here - http://gadgets.vectric.com/V10/dovetail.html
Using that version I can create toolpaths for your file without the error.
George B.
Post by George B. »
Thank you for the link! That solved the problem. Vectric "about gadgets" selection not clear as to how to get (V10) there in my mind. Thanks for the help!
