I'm starting to learn Lua for the purpose of building gadgets for VCarve Pro 10.0. Where can I find information on which Lua version VCarve uses?
The current version is Lua 5.3.5 and it's been out for well over a year and Lua 5.3 dropped almost four years ago. The differences probably won't matter much but I want to make sure I'm using the correct reference materials, just in case there are bugfixes that affect what I might be working on.
Which version of Lua does VCarve use?
- Model of CNC Machine: CAMaster Stinger II (SR-44)
- Model of CNC Machine: CNC Shark
Re: Which version of Lua does VCarve use?
Have you tried printing the global variable _VERSION? Maybe MessageBox("Lua version " .. _VERSION)
- Model of CNC Machine: Legacy Maverick 4x8, BOSS laser
My Aspire 10.512 says it's Lua 5.2!
- jimandi5000
I have found no real issues with any of the versions.
Here is my Wiki site and there is a lot of code you can use to get started.
https://jimandi.com/SDKWiki/index.php?title=Main_Page
Here is a set of How to videos.
https://youtu.be/skSQ3iCaUu4
If you have questions let me know.
Jim
Jim
