Turned Pattern x leg error
Raney618
Model of CNC Machine: Workbee
Re: Turned Pattern x leg error
Post by Raney618 »
The pp that I am modifying produces a string of
G1A0.000
Move y
G1A360.000
Move y
G1A0.000
Move y
G1A360.000
Etc
So the rotary rotates back and forth and slowly moves down the object to round it into a cylinder.
Tomorrow I will send you the pp gcode and output.
Raney618
Post by Raney618 »
Hi Randall
The following pp is the one i have modified. The resulting Toolpath which i have not run yet is included also. Your cursory look would surely be appreciated.
ONZ2_Raney__wrap_X_on_Y_inches.pp
(2.43 KiB) Downloaded 11 times
Rounding Toolpath.pp
(516 Bytes) Downloaded 11 times
Post by Rcnewcomb »
They look fine. I'm curious why your toolpath files have a .PP extension.
10 fingers in, 10 fingers out
another good day in the shop
Raney618
Post by Raney618 »
Hi Randall
I was using onz…. Post processor to modify. I took your suggestion and added a post_name and a rotary_wrap_x = “A”. It would not work. I looked and looked for the bug and found that taking out a P in a g1 x y z p f it all worked. It was like the blind leading the blind. I still have a rotation problem. I need to change the multiplication factor in a x variable. I have a 100:1 rotary drive so with 1.8 deg step, and 100:1. How must x be multiplied by what to equal 360 deg. I think that is the problem. I came up with 55. Do you have thoughts. I am going to try it out this afternoon.
Why *.pp, I found that placing a pp in the pp list requires a *.pp. I know that doesn’t make sense since there are other extensions in the list, but it works. Again, do you have any advice.
“Bootstrapping each leg of my pants” but fun.
Thanks for your guidance
Post by Rcnewcomb »
First let's get the basics of the machine figured out.
Checking Rotary Calibration
  • Put a piece of material in your rotary setup
  • Send the rotary axis to its home position with the command G1 A0
  • Put a pencil mark on the material
  • Tell the rotary axis to move one revolution with the command G1 A360
  • The pencil mark should be at the exact same location
  • Send the rotary axis back to its home position with the command G1 A0
  • Again, the pencil mark should be at the exact same location
  • Tell the rotary axis to move 100 revolutions with the command G1 A36000
Let us know the results.
Raney618
Post by Raney618 »
That is truly extensive, more than I had thought of. Will do, but grandkids come in tomorrow, so it may be a few days till i get some results. I will also have to make some adjustments along the way possibly. Possibly for sure.
Raney618
Post by Raney618 »
Since i don't have control hooked up to my cnc is there a way to use INTERFACE to send code pieces. If not i might have to write a gcode program to run pause run pause etc.
J
Post by Rcnewcomb »
I have no idea how your machine operates so I cannot advise.
