In the Labs – Rustic Oak Stool FREE PROJECT
Stephanie Downing
Vectric Staff
Model of CNC Machine: xxx
Post by Stephanie Downing »
In this month’s “In The Labs” project, Todd shows you how to make a rustic oak stool with two easy to machine options using either VCarve or Aspire for those new to CNC or wanting to expand their skills!
Check it out:
Firstly Todd cuts the test piece to ensure the fluting toolpaths cut correctly in the oak material as he had a new bit he's never used before. Todd came up with the scalloped bowl as it's a handy extra small project that can be reused separately but also, doing a test piece is really vital if you don't want to waste time and materials. As it happens, the initial feeds and speeds for the test part seemed too fast, so for the final cut Todd slowed it down and adjusted the step-down - things he would not have known without cutting a test part!
For the four legs and bottom plate, Todd uses a simple design that can be profiled in VCarve or Aspire, adding a splayed shape to the legs as a bit of styling, then he cuts the base plate with fixings for each leg top, glues it to the underneath of the seat then slots in each leg, adding more glue to secure. Todd did want to have longer legs so it could be a bar stool but ended up producing a shorter stool which looks just as neat as well as accommodating VCarve Desktop users! Why not play around with Todd's seat designs and make your own rustic stool as a perfect accessory for your woodshop or styling prop to give height to your home decor or interior displays!
We've included both versions of the seat in this FREE project giving you the choice to either cut the VCarve version then use a sander to get the finish, or machine the 3D model in Aspire without the need for hand finishing! Also both files include the bottom plate and shortened legs that can be easily lengthened to give it more height.
Click here to download the files from your V&CO account: https://www.vectric.com/vectric-communi ... icOakStool
If you’ve been inspired to make your own tools, we would love to see what you’ve made so don’t forget to share them here or tag us on our socials.
Happy making!
