Post for Biesse Rover B 4.75ft
Big-Tex
Post by Big-Tex »
Sorry posted in wrong section......
It looks like am out of luck cause v-carve does not have post for machine we have at work.
here is info Biesse Rover B 4.65ft I believe it is xp600,NC1000,XNCmm extention ISO controller.
If you guys can write one up that would be awesome.
THX
We had same issue with ArtC demo when we tested, lack of post, other Biesse posts would not work.
Sample g-code created by other soft
[COMMENTO]
[CENTRO01]
PARAMETRI=000000214
UTENSILI=000000363
LABELF=000000000
LABELC=000000000
FORATURA=000000000
CONTORNATURA=000000380
TABELLEFORI=000000000
CONFASSIST=000000000
ATTREZZAGGIO=000000000
[PARAMETRI01]
N10 G71 HC=1 LY=565.150 PLPZ=19.304 PDM=0 PUOS=0 FIL=0 BLO=0 ACC=0 RUO=1 PRS=1 PRL=1 PPWQ=0.000 KA=256.000 LZ=19.304 LX=1397.000
[UTENSILI01]
[CONTORNATURA01]
N18 PAN=1 ST1="1/2DOWN" ST2="NULL" ST3="NULL" L=PCUA
N19 X0.000 Y-0.000 TP=1 PRF=-20 VF=10 F14 G40 L=PON M55
N20 G0 X15.875 Y91.369 Z-63.500
N21 G1 Z-14.580 F10
N22 G1 X1355.725 F14
N23 Y88.036
N24 X15.875
N25 X15.875 Y91.370
N26 X1355.725 Y91.370
N27 Y88.036
N28 X15.875
N29 G0 Z-63.500
N30 G0 X15.875 Y481.736
N31 G1 Z-14.580 F10
N32 G1 X1355.725 F14
N33 Y478.402
N34 X15.875
N35 Y481.736
N36 X1355.725
N37 Y478.402
N38 X15.875 Y478.402
N39 G0 Z-63.500
N40 G0 X0.000 Y-0.000
N41 L=POFF
1/2DOWN
Wood --> nature created, never duplicated......
http://campbelldesigns.net/
Re: Post for Biesse Rover B 4.75ft
Big-Tex
Post by Big-Tex »
I will give it a try, but I think I have went that rout before.
Mark
Vectric Staff
Post by Mark »
Hello Big-Tex,
I have emailed you a post processor to try.
I have had to take a few guesses, but please give it a try
and email me if you have any problems with it.
Cheers,
Mark.
Big-Tex
Post by Big-Tex »
Thx I will try probably tomorrow as soon as I find minute that router is not used for normal production.
DanielBEE
Model of CNC Machine: n/a
Post by DanielBEE »
Where are you getting stuck?
Aspire 2.0
Biesse Rover A 3.30
Biessworks
PC/Mac Draft
AutoCad
AutoDesk Inventor
Trumpf
Big-Tex
Post by Big-Tex »
Machine spits out error code ANT 1000655
DanielBEE
Post by DanielBEE »
Hmm, I haven't seen that one before, I wonder if our Rover's have different software/error messages.
So the program start, or does it giv eyou that message as soon as you hit the go button?
-Daniel
Aspire 2.0
Biesse Rover A 3.30
Biessworks
PC/Mac Draft
AutoCad
AutoDesk Inventor
Trumpf
Big-Tex
Post by Big-Tex »
Limits point of XY 0,0 is right as per machine.
Also name of tooling has to correspond what is set up on machine, that I have set up correct as well
Yes I get this error message as soon as I hit go........
P.S Biesse works that is supplied with machine is not able to open it just to see graphic of part as well.
DanielBEE
Post by DanielBEE »
Biesseworks won't open the Biesse posts from Vectric. I guess its because Biessworks is its own program, and generates its own code, it can't read code however.
Try to find the old Editor on your computer its a blue box. It can read the code and open the file. From there you can check and make sure everything looks right, and if you save the file from inside the editor if the code doesn't work it will generally tell you why.
Aspire 2.0
Biesse Rover A 3.30
Biessworks
PC/Mac Draft
AutoCad
AutoDesk Inventor
Trumpf
bigZ
Post by bigZ »
I don't want to hijack this thread but is their a way to transfer the posts to a Biesse Rover with a NC481 via floppy from a PC. The problem seems to be the file format. I once successfully ran a program from a Vectric post by hand typing it in. I could run your program attached but would have to modify it too:-
N10 G71 HC=1 LY=565.150 PLPZ=19.304 LZ=19.304 LX=1397.000
N18 PAN=1 L=PCUA
N21 G1 Z-14.580 F10
N23 Y88.036
N24 X15.875
N25 X15.875 Y91.370
N27 Y88.036
N28 X15.875
N29 G0 Z-63.500
N31 G1 Z-14.580 F10
N33 Y478.402
N34 X15.875
N35 Y481.736
N36 X1355.725
N37 Y478.402
N39 G0 Z-63.500
N41 L=POFF
blackvisionit
Model of CNC Machine: ESA/GV
Post by blackvisionit »
Biesse ROVER equips a C.N.I. controller with 800Kb floppies.
800Kb floppies are 720Kb DD that are overformatted.
Anybody interested in a USB emulator for that floppies
should take a look at embeddedsw.net - EMUFDD4.
