Acorn Post Processor
I just tried a centroid post on my new Acorn controller and after the job ended the spindle did not retrack and stayed at the end spot. I am used to the Shopbot post that has the spindle raise up and go home. does anyone have a post for that
- IslaWW
Re: Acorn Post Processor
You can take any lines of code you wish from the SB postP and copy them to the Centroid postP. (with gcode thranslation if needed)
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
Thank you Gary Now I have to find the post processor for aspire 8.5 on a windows 11 machine. it was real easy on my older windows computers but they change names and locations on this one
- IslaWW
Jerry...
There is also a "single tool" Vectric postP that I posted on the Centroid Acorn Support Forum that was designed with reduced features that match what guys coming from ShopBot are used to.
Gary Campbell
GCnC Control
GCnC Control
In Aspire, under the File menu, select Open Application Data folder. It should be in there.fixtureman wrote: ↑Thu Mar 02, 2023 4:31 pmNow I have to find the post processor for aspire 8.5 on a windows 11 machine.
