I've edited the .pp file for my Avid CNC (inch) (*.txt) as described in the Vectric documentation (which still contains an error in the Block Numbering section: it should read "LINE_NUMBER_START=0" but it reads "LINE_NUMBER=0"), but no block numbers are present in the generated toolpath output file.
I added the following:
andLINE_NUMBER_START = 10
LINE_NUMBER_INCREMENT = 10
I also added [N] to most every Command output section I could find - like this:VAR LINE_NUMBER = [N|A|N|1.0]
Saved my changes, opened VCarve, which threw no errors like it does when it finds something it doesn't like.VAR LINE_NUMBER = [N|A|N|1.0]
Opened my project file and recalculated the toolpaths then saved the toolpath file.
No joy:
Can someone please explain what I'm missing?(VECTRIC POST REVISION)
(CF5A38FE52364C8CCD7F2AB294DB806B)
( Hold Down Knobs - Soft Maple - TEST )
( File created: Friday January 06 2023 - 06:22 PM)
( for Avid CNC Machines, post processor v3.0 )
( Material Size: X= 22.000, Y= 9.750, Z= 0.938)
( Z Origin for Material = Material Surface)
( XY Origin for Material = Bottom Left Corner)
( Min Program Extents: X= 0.000, Y= 0.000, Z= -0.938)
( Max Program Extents: X= 22.000, Y= 9.750, Z= 0.000)
( Home Position: X =X0.0000 Y =Y0.0000 Z =Z0.8000)
( Safe Z = Z0.2000)
(Toolpaths used in this file:)
(EM250SUC - TeeNut Pocket)
(EM250SUC - Thru Hole - Profile)
(EM250SUC - Knob Profile)
(Tools used in this file: )
(1 = {1/4"} SRF4-250UP - Up-Cut Spiral Bit)
G00 G94 G20 G17 G90 G40 G49 G80
G91.1
T1M6
M07
G00 G43Z0.8000H1
S16000M03
(Toolpath: EM250SUC - TeeNut Pocket Tool: {1/4"} SRF4-250UP - Up-Cut Spiral Bit)
X0.0000Y0.0000F170.0
G00X2.2998Y3.5830Z0.2000
G1Z0.0000F100.0
G1X2.2977Y3.5829Z-0.0001
G1X2.2955Y3.5824Z-0.0003
G1X2.2934Y3.5817Z-0.0004
G1X2.2913Y3.5806Z-0.0006
Cheers,
nf
