Good Day to everyone!
I'm trying to get my Side Milling Unit to work, it is Syntec 6MB Controlled. What I'm trying to do, is change the Post Processor so that it will change the X+ into Z-. and Z- into X+.
how can i do that? Anyone have a clue?
Changing Post Processor for Side Drill
- BenjaminwithCNC
- Model of CNC Machine: Danibrum 1325 ATC Rotary 4x1
- Syntec_arc_mm.pp
- (4.24 KiB) Downloaded 150 times
Re: Changing Post Processor for Side Drill
Rather than trying to remap the X & Z axes via the post-processor how about rotating the cutting plane instead: https://www.cnc.com/g17-g18-g19-plane-selection-gcodes/
The conflict with remapping the axes is that you, in a sense, want "Z" to be both positive and negative depending on whether it's X mapped to Z or Z mapped to X.
- BenjaminwithCNC
Thank you a lot. I looked into it, now here is my question, if the Side milling unit is on the left side of my material and i want to mill a rectangle on the left side, where do i place the rectangle so it mills it right?
Would that mean,to use the Cut depth for the positioning and the X position as a Cut depth?
I'm confused
I'm confused
- Leo
Plane selection is more about G2 G3 arc cutting. If I were going to Gcode the side drilling I would just use the X oy Y commands
In vectric, I would do something with a profile ON a line tools.
- BenjaminwithCNC
I think i'll go back to the initial Question about Post Processor, that way i can draw it with Vectric, only thing, how to change X to Z and Z to X.
i searched about the Wrap Function but it uses this one: ROTARY_WRAP_X = "-A", which is explicitly Rotary. Manuals don't show anything.
Thank you for your time.
Benjamin
Benjamin
- BenjaminwithCNC
Good morning,
I tried using this:
SUBSTITUTE = "O1 S1 O2 S2 On Sn"
but it don't think i can use it only i a Segment. So that i could move the Side unit to X-10 position and then start my milling.
I tried using this:
- SteveNelson46
Generally speaking, post processors are controller/machine specific and are usually written by machine or controller manufacturers and provided to Vectric by request. Many here on the forum are good with writing g-code but few are familiar with your machine or controller. I think your question would be best answered by your machine or controller manufacturer.
Sorry about the wrong lead on remapping the XYZ plane using Gxx commands. I knew such a feature existed but I didn't realize it was only for arcs.
I still think re-orienting the XYZ plane on the machine is the way to go and you might just have found something. But as Steve mentioned we don't know your machine so can't really verify it for you.
Back to your question about altering the post-processor file (and part of me doesn't even want to post this information):
In the following I'm using lines from my post-processor. You'd have to find similar ones in yours. I guess the easiest way to do that is changing the lines:
to
This should work but I haven't verified it. Also, it would be incumbent on you to set up your job so that the remapped X and Z axes go in the right positive and negative directions. Also, there might be other variables that would need swapping.
Also, if your post processor uses: ???_ARC_MOVE entries you'd probably want to comment them out as I'm not sure how they would react to the remapped axes without a remapping of the XYZ plane...
Code: Select all
VAR X_POSITION = [X|C|X|1.4]
VAR Z_POSITION = [Z|C|Z|1.4]
VAR X_HOME_POSITION = [XH|C|X|1.4]
VAR Z_HOME_POSITION = [ZH|C|Z|1.4]
VAR SAFE_Z_HEIGHT = [SAFEZ|A|Z|1.4]
Code: Select all
VAR X_POSITION = [Z|C|X|1.4]
VAR Z_POSITION = [X|C|Z|1.4]
VAR X_HOME_POSITION = [ZH|C|X|1.4]
VAR Z_HOME_POSITION = [XH|C|Z|1.4]
VAR SAFE_Z_HEIGHT = [SAFEZ|A|X|1.4]
- BenjaminwithCNC
Thank you very much for that piece of Information.
This helped a lot.
This helped a lot.
