Hello everybody,
I found another bug that prevented the postprocessor from reading.
In version 10 it is possible to load post processors with ä, ü, ö in the name.
In version 10.5xx, the postprocessor name cannot contain ä, ö, ü
Also with the parameter POST_NAME =
these characters may not be used
Dieter
PostProcessor Problem
Re: PostProcessor Problem
Make sure to send this into support@vectric.com
- DJ-Bino
- Model of CNC Machine: Versatil 1800
Hi Randall,
It is a PP from a customer. Mohamed already knows.
It is a customized PP that also works if you rename it.
It has an ä in the name and also for the variable
POST_NAME = is an ä in the name.
This worked well until version 10.22
From version 10.5xx this no longer works.
Here is another example:
Milling = Fräsen in German Translation
Mach3 fräsen 3Axis.PP (that's the PP Name)
POST_NAME = "Mach3 fräsen 3Axis (* .nc)" (that's the variable)
If I rename the PP to Mach3 fraesen 3Axis.PP and change the variable to POST_NAME = "Mach3 fraesen 3Axis (* .nc)" then everything is OK in version 10.5xxx
I think Aspire 10.5xx has Problems with the charter äÄ, öÖ, üÜ
Dieter
The processor does actually work but it displays as a blank name in the list.
- DJ-Bino
Hi Adrian,
I knew it was working. I just had to rename it. Both the name and the variable POST_NAME =
Otherwise nothing had to be changed.
Thanks Dieter
Thanks Dieter
