Editing a post processor, duplicate post processor name.
anotherdamnaccount
Model of CNC Machine: ShopSabre 4896
Post by anotherdamnaccount »
Hello there,
I recently duplicated the post processor that I use and made a version that doesnt turn the spindle on, for use with a marker and dragknife.
When I open Vectric VCarve Pro 8.5 I am getting an error message - duplicate post processors found, change the name under "POST_NAME=" The two do have different names and I still am getting this error message.
Here is the post I am using
Here is the post I have altered. Notice the different name under "POST_NAME="
Any ideas?
IslaWW
Re: Editing a post processor, duplicate post processor name.
Post by IslaWW »
Along with the "Post Name", have you changed the actual xxxxx.pp file name?
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
adze_cnc
Post by adze_cnc »
All three images show that the .pp name is different.
Can't see anything obvious. Assuming you saved the file with the changed post name (more than a few times I've been baffled why a program wouldn't work but the code in the editor hadn't been saved...) all I can think of is it that it's some sort of caching issue. Have you tried rebooting to see if it works then?
anotherdamnaccount
The two .pp files have different names.
I rebooted the computer and still the same.
I had the same problem a few years back and dont remember how I solved it. When I upgraded this computer from Win7 to 10 I forgot to store my posts. It was time to change the posts back to the way I like them and now this problem again.
Post by Rcnewcomb »
Can you Zip both .PP files and upload them to the forum?
10 fingers in, 10 fingers out
another good day in the shop
anotherdamnaccount
Sure thing, both posts attached.
My_PostP.zip
(2.46 KiB) Downloaded 14 times
Those files have different names but the POST_NAME is still the same.
anotherdamnaccount
Woa. Notice in my screenshots they are the same. I wonder if the problem is the editor I am using
anotherdamnaccount
OK, so the editor I was using "Visual Studio Code" does not automatically save the file when you close it and when you re-open the file your changes show up even though they do not exist in the source file. So what VCarve saw was a duplicate of the same file. Opening the file and choosing file - save and the problem is solved.
I just tested and Visual Studio Code behaves the same way with .tap files... it must be how it behaves with all files.
gkas
Post by gkas »
That's why I use NotePad++ to edit ALL my text files, unless I'm using a compiler IDE. It doesn't mess up what you've got. It does indentation, auto EOL conversion, Macros, etc. It's a standard in the coding world. The Macros are great for easily making semi-automatic changes.
https://notepad-plus-plus.org/
Post by Rcnewcomb »
I am another satisfied Notepad++ user.
For programming I use Sublime Text because it runs on both Windows and Mac.
I use EditPlus for everything (the editor in my screenshots above) and it's great. Looks like the Visual Studio editor works in a similar way to the graphics package I use (Xara) in that it will open with the same files used previously along with changes even if they haven't been saved.
One clue that I missed in the original screenshots is that the second file has a marker (the dot) to show it's been updated but not saved.
