Hello,
I have a small problem with my post processor and wanted to see if you could help me correct it. I am using the "Holz-Her_Conquest_ATC_Inch" post and there is 1 line of text my machine does not understand. See screen shot attached. I opened the program in notepad and closed the parenthesis after "END MILL" and it ran correctly. How can I fix this in the post? Any help would be apprecated.
Paul
- Model of CNC Machine: cosmec conquest 510
Re: Holz-Her_Conquest_ATC_Inch"
There are two options. One is to amend the post processor itself and the other is to just change the tool name in the tool database.
In the post process it's the "([TOOLNAME])" lines that you need to amend or remove. There is a post processor editing guide on the Help menu in the software.
