Need help with Gerber post processor
Mikehell
Model of CNC Machine: eBay special China 3040
Post by Mikehell »
I have a Gerber Sabre CNC. It does have the firmware version that will accept GCode. I have a post processor that was there when I started. The current post processor produces G-Code that's much larger than it should be. Example, I did a design that was a simple rectangle, single pass. File size is 15k, Almost 200 lines. Output to a normal GCode file is 2k. .
It looks like the post processor is breaking the thing into very small segments..
This machine is said to be able to accept "limited" GCode commands, but I can't find which commands these are anywhere.
I have attached the current post processor file
Gerber_Sabre_inch.pp
(2.92 KiB) Downloaded 19 times
Re: Need help with Gerber post processor
You've posted the same question in the VCarve section - http://forum.vectric.com/viewtopic.php?f=2&t=33784
