Edit Mach 2 tool change routing
Zcases
Post by Zcases »
I am using the Mach 2/3 ATC Arcs Inch post. I would like to add a line in the post to do a G53 Z0, to bring the spindle up at the end of each tool. Then of course, have the control go back to the work offset used prior to the toolchange (G54, 55, etc....).
Any help available with the code to do this?
Scott
garyb
Re: Edit Mach 2 tool change routing
Post by garyb »
add them to the m6 macro in Mach
Gary
Beckwith Decor Products
Custom CNC Tooling/Onsrud Distributor
http://www.beckwithdecor.com
ger21
Post by ger21 »
begin TOOLCHANGE
"[N]G53 G0 Z0"
"[N]T[T]M6"
"[N] (Tool: [TOOLNAME])"
"[N]G43H[T]"
You'll still be in the same work offset you were in.
