Acromatic A2100 Controller
Woodbutcher-59
Model of CNC Machine: Homebuilt 3'x5'x6"
Post by Woodbutcher-59 »
I'm trying to do a simple Vcarve of some text on a buddys mill...it is a Cincinnati mill with an Seimens Acromatic A2100 Control.
I tried the PP that is named Cincinnati and it did not work correctly on the mill.
We also tried the Fanuc PP cause he thought the code was similar but no luck.
Does anyone know of a PP that will work for this controller ??
Jeff
Aspire 8
Mach 3
" I'm tryin to think but nothin happens " - Curly Howard
Woodbutcher-59
Re: Acromatic A2100 Controller
Hi all,
It turns out the code generated by the Cincinnati PP did work OK with a small manual edit.....I was not there so I'm not sure what they did to make it work but all is well.
I kinda knew something had to work with this controller, but its a little harder to figure it out by Email.... :roll:
Jeff
Aspire 8
Mach 3
