Hi everyone. Thanks in advance for any help with this!
I am trying to find a compatible post processor for a Chinese made CC-MS1325AC CNC router. It is a 1300x2500 machine with ATC. It uses the NK105G3 controller. I use vectric carve pro to generate the files that are loaded on to the USB port of the machine.
My existing machine (Piranha PJCM1325-3) is very similar but does not have ATC and uses the NK105G2 controller (next model down but same control box). This post processor appears to work fine on the new machine but will obviously not handle any tool changes.
I did a good search on here (and google) but could not find a post processor. I thought this was a little odd as it is a very common controller and most of the chinese imports use it.
Any help would be much appreciated.
Post processor request - Weihong NK105G3 controlling a CC-MS1325AC
- Model of CNC Machine: Home made CNC on wood lathe
Re: Post processor request - Weihong NK105G3 controlling a CC-MS1325AC
Hello,
I am i the same situation with Weihong NK105G3 controlling a 3 axis with 6 ATC.
Did you find the good post processor with Vcarve to drive your ATC CNC ?
Frédéric
Frédéric
The forum is mostly user to user so unless there is a user with the same sort of set up then you probably won't get a lot of response on the forum, there is a post-processor editing guide which should help you modify one yourself if you can do that. If not then you would probably be best contacting vectric support directly
support@vectric.com
- jfederer
- Model of CNC Machine: CanCam D23M
My machine, a CanCam D23, uses the Weihong G3 controller.
Here are the PPs I use. I have no idea if they will suit your needs, so use with EXTREME caution!
Joe Federer
www.fabrikisto.com incl. Tailmaker software
www.federer.ca
www.federer.ca
