What are the G-code commands to rotate the A-axis?
RotateIt
Model of CNC Machine: Onefinity
Post by RotateIt »
I have a rotary installed on a Onefinity CNC. I would like to execute a four-sided Job.
I would use the regular post processor to cut the first side, a regular XYZ carve.
Then I would like to rotate the piece by 90 or 180 degrees.
To do that I would install the rotary post-processor, and swap the Y for the A cables, the machine and Onefinity / Buildbotics controller has only 3 axis, rotate the Rotary by 90 degrees, install the regular post processor and so on.
I am not at all experienced with g-code.
What are the G-code commands to tell the A-axis to rotate by 90 or 180 degrees?
Many thanks
R
4DThinker
Re: What are the G-code commands to rotate the A-axis?
Post by 4DThinker »
G0 A90
G0 A180
G0 A270
etc..
RotateIt
Post by RotateIt »
Thank you so much!
