Rotary Top at Angle
Wayne Locke
Model of CNC Machine: Shopbot
Rotary Top at Angle
Post by Wayne Locke »
Is there a way to turn this stair balluster
with an angled top of about 36˚ and keep the flair? I can't find a way but I may well be missing something.
Re: Rotary Top at Angle
Post by Rcnewcomb »
Should be doable with the moulding toolpath. Do you have a clean vector of the profile?
Wayne Locke
Thanks Randal. Here is part of the file with the basic shape. The Moulding Toolpath seems to be in the right direction but I seem to have missed a couple of turns.
Balluster_2z.crv3d
(1.3 MiB) Downloaded 63 times
SteveNelson46
Post by SteveNelson46 »
It might be do-able with a moulding toolpath but I think a 2 rail sweep would be easier. At least for me anyway.
Balluster.zip
(2.49 MiB) Downloaded 58 times
Wayne Locke
Here is how I ultimately arrived at something usable if I decide to do it. The 2 Rail Sweep worked better for me than the moulding toolpath and is also my intuitive go to tool for this kind of thing. After many iterations of the Drive Rails I settled on the vee shape which results in a point at the connection point.
There may be a mathematical way to arrive at an elliptical shape which would eliminate the point but my degree is in English so I can only describe not calculate. I eliminated the components in the uploaded file so that it would be small enough to upload but you can see the rails and the cross section I used as well as some vectors for trimming the top component. You can create a 2 Rail with the file.
Every iteration left junk on the ends.
I added Dowell components on the ends for mounting. This also negated some of the artifacts.
I finally added a component labeled Texture to give it a hint of Art Nouveau.
With the texture the points became less objectionable and contributed to the design.
If someone has other ideas I am all ears.
Balluster_Forum.crv3d
(23 KiB) Downloaded 51 times
SteveNelson46
I gave you the completed file with a 2 rail sweep. Was there something wrong with it?
Wayne Locke
I had already done a straight 2 rail but was having trouble with placing an angle on both ends. I appreciate your file but it is the same as my original example and the file I posted in my second post. Your file does not address tapered ends which was my problem.
SteveNelson46
Without a picture or something to compare to I don't understand what you are trying to do.
Wayne Locke
See my last post with images.
adze_cnc
Post by adze_cnc »
Steve: This seems to be what's wanted. A knobbly baluster that has each end cut at an angle to run under a hand-rail and along a stringer.
Can that done by modelling in something then subtracting it from the bulbed end?
Steven
The stem of this "mushroom" is a dowel to be slotted into stringer or hand-rail
Wayne Locke
I'm sorry if I wasn't clear. My recent post with a file and 4 or 5 images I thought illustrated and explained it. You cannot merely subtract a shape because I want to have the flare as Adze called it follow the angle around. Although this is a screenshot and not very good, I think that it shows what I am shooting for. .
Thank you for your efforts.
SteveNelson46
adze_cnc wrote:
Sat Jul 09, 2022 11:34 pm
Steven
Maybe, but I think it would take more work and experimentation. At least for me. I could model it in Rhino, as you did, but I don't think that would help him.
