I have my file(s) set up with Z at the center point of the stock, and if I go to material setup under "Home / Start Position" for Z Gap above Material it's 8mm. The diameter is set correctly and I'm using a cylinder for stock. But when I export the toolpath and import it into either universal gcode sender platform or basic sender, the simulation in that program shows the bit start at 0,0,0 before moving up to a path above the stock. If I ran that, it would first try to drill down to the center of my wood, much tears, death, etc.
How can I prevent the toolpath returning to Z 0?
Toolpath wants to start at Z 0
Re: Toolpath wants to start at Z 0
If that's something you can't over ride in your controller software I expect that in your post-processor there is a line to do a return home in the "begin FOOTER" block (it could look like this):
The fix would then be to remove the "[ZH]" at the least
Code: Select all
"[N]G00[XH][YH]"
- SteveNelson46
Oops. My brain totally skipped the cylinder sentence.
I'm using the post processor that was recommended by the manufacturer. Called XZAR 1.1.
Here's the footer part -
Edit: I'm going to try removing the line G0[ZH] as soon as I can get back to my cnc.
Actually, here's the whole file, in case it's relevant -
Code: Select all
begin FOOTER
"M5"
"G0[ZH]"
"G0[XH][YH]"
"M2"
Code: Select all
POST_NAME = "XZAR (mm) (*.gcode)"
FILE_EXTENSION = "gcode"
UNITS = "MM"
ROTARY_WRAP_Y = "A"
+ Line terminating characters
LINE_ENDING = "[13][10]"
+ Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+ Formatting for variables
VAR WRAP_DIAMETER = [WRAP_DIA|A||1.4]
VAR LINE_NUMBER = [N|A|N|1.0]
VAR POWER = [P|C|S|1.0|10.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.4]
VAR Y_POSITION = [Y|C|Y|1.4]
VAR Z_POSITION = [Z|C|Z|1.4]
VAR X_HOME_POSITION = [XH|A|X|1.4]
VAR Y_HOME_POSITION = [YH|A|Y|1.4]
VAR Z_HOME_POSITION = [ZH|A|Z|1.4]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"T1"
"G21"
"G90"
"G0[XH][YH]"
"G0[ZH]"
+ Command output after the header to switch spindle on
begin SPINDLE_ON
"[S]M3"
+ Commands output for rapid moves
begin RAPID_MOVE
"G0[X][Y][Z]"
+ Commands output for the plunge move
begin PLUNGE_MOVE
"G1[X][Y][Z][F]"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"G1[X][Y][Z][P][F]"
+ Commands output for feed rate moves
begin FEED_MOVE
"G1[X][Y][Z][P]"
+ Commands output for the first clockwise arc move
+ Commands output when the jet is turned on
begin JET_TOOL_ON
"M4[P]"
+ Commands output when the jet is turned off
begin JET_TOOL_OFF
"M5"
+ Commands output when the jet power is changed
begin JET_TOOL_POWER
"[P]"
+ Commands output at the end of the file
begin FOOTER
"M5"
"G0[ZH]"
"G0[XH][YH]"
"M2"
Note that a reference ZH is also in the "begin HEADER" section (that is at the beginning of the cut).
Thank you for pointing it out. I'll try removing that one too.
Amusingly, that made the open toolpath look different, but the new one is also starting at Z0. It used to start at Z0 and move directly up to above wood, and now it starts at Z0 but has more of a slope moving toward the center of the wood to start. I'm going to try asking about the sender software and see if it's a setting in there, too.
