Text on a convex shape
- mtylerfl
Re: Text on a convex shape
Hey Steve,
VCarve cannot import a 3dclip file
- SteveNelson46
Isn't the .3dClip format distributed with V-Carve? I've never owned V-Carve but I thought all of the clipart was the same.
- mtylerfl
Nope. Models included with VCarve are all in the proprietary v3m format.
The Aspire software can use both 3dclip and v3m formats.
So, if you create a 3dclip from a model created in Aspire (which I have done religiously for years), it is useless to a VCarve software user. Instead, you could save/export as STL, for example, so the VCarve user can import that.
The documentation for VCarve back as far as 9.x mentions importing and exporting 3Dclips but the actual program doesn’t match the docs.
- SteveNelson46
Well, If the 3dClip didn't work then an .stl file should. Here is the link.
https://drive.google.com/file/d/1o1VusN ... sp=sharing
- mtylerfl
How odd! It's clearly a mistake/oversight for that to be stated in the VCarve documentation.
VCarve has never been able to import 3dclip nor export an individual model to 3dclip (or to export to any other 3D model type).
From v11.0 Vcarve Pro docs: https://docs.vectric.com/docs/V11.0/VCa ... -3d-model
Elsewhere it mentions exporting by using the context menu on a level in the component tree.3D Clipart files are exported from VCarve Pro. This format maintains the component structure of clipart pieces at the time of saving, so will import all the components comprising the clipart piece. This will be imported at the size and position the part was saved in the original file.
- mtylerfl
Steven,adze_cnc wrote: ↑Fri Jan 07, 2022 10:07 pmFrom v11.0 Vcarve Pro docs: https://docs.vectric.com/docs/V11.0/VCa ... -3d-model
Unfortunately, this is incorrect. The documentation is describing Aspire-only features, despite the fact that it says VCarve will perform those functions.
- Model of CNC Machine: Sorotec
is there another way to draw a simple text on a curved body. for example a ballpoint pen
- IslaWW
Of course. Simply have a 3d model of the shape loaded and "aaply toolpath to Model"
Look about 6 minutes in here:
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
It mean ragt i habe to create the stl file in Another Programm and import into vectric
Is there another way to do this ?
If you're using VCarve then yes you need to create a model of the shape you want to project onto if none of the supplied shapes are suitable.Nero-12345 wrote: ↑Wed Jan 19, 2022 12:58 pmIt mean ragt i habe to create the stl file in Another Programm and import into vectric
If you have Aspire then you can create the model directly.
Ok many thanks ill try it
