table legs
vfauto
Model of CNC Machine: Legacy Artsian 72"
Re: table legs
Post by vfauto »
mezalick wrote:This was cut from a 6" diameter piece of wood.
Square ends are possible to cut on the rotary.
Michael
how did you draw it?
Thank You
Frank
mezalick
Re: table legs
Post by mezalick »
It takes a bit of thinking but "dealguy11" gives a real good explaination in the above messages.
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
dealguy11
Re: table legs
Post by dealguy11 »
Frank, I left you a PM with step-by-step instructions.
Steve Godding
zombolina
Model of CNC Machine: Shopbot PRS
Re: table legs
Post by zombolina »
Hi mezalick,
I know this is an old thread, but I wonder if you could tell me how to get the shoulder on the rectangle part of the leg?
Couldn't figure out how to PM you!
Thanks!
S
Re: table legs
Post by Rcnewcomb »
It is similar to the tapered Octagon, but with 4 sides instead of 8: Tapered Octagon Thread
10 fingers in, 10 fingers out
another good day in the shop
SteveNelson46
Re: table legs
Post by SteveNelson46 »
Vectric has a video on how to model a spindle using the un-wrapping process.
https://www.vectric.com/support/tutoria ... _Machining
I would use the cnc to do the work. Then re-mount it in the lathe for sanding. I have done this many times for rotary projects and it works really good. Of course, if you have really good lathe skills and/or a duplicator for the lathe it would be much faster to just use a lathe as long as you don't need a multi-faceted shape other than a square.
