I am using shopify and want to add the web catalog offered by design&make
two ways to add it and it says content not available
suggestions plz
D&M web snippet
Moderator: Todd Bailey
Re: D&M web snippet
Ask on the Shopify forum?
- Todd Bailey
- Vectric Staff
- Model of CNC Machine: CraftCNC
Re: D&M web snippet
Hello, Aroff.
Thanks for the question and well seeing as every platform does it a bit differently I can only speak from the experience we have had and up till now yours is the first Shopify that I have seen.
So for others, it really seems to be an issue with how you were testing the snippet. If you view it from inside your store editor then you will get that message but it should work if you view it from the URL that you signed up for it with.
For example, your editor will be reporting to our system the URL of the editor and that will not resolve properly seeing as the snippet is tied to your customer-facing URL.
Now on the other hand if from the customer-facing URL the snippet is still not working then feel free to contact us through support@designandmake.com and we can try to get it worked out.
Please let us know either way if that helps.
Todd Bailey | Design and Make
DesignAndMake.com
DesignAndMake.com
