Xilog3 questions
dustboy
Model of CNC Machine: Centroid router, Morbidelli Author 504
Xilog3 questions
Post by dustboy »
I have a new-to-me Morbidelli Author 504.
I'm testing the included post processors, (Morbidelli 336 NBR Arcs (inch)) I can get Xilog to open the .PGM file (after compiling the .XXL with WinXiso) but I'm having issues with the tool numbering. "xISO: Tool numbering not permitted."
In Xilog, E6 is the tool in position #6 in the tool changer. VCarve won't let me number a tool with a letter. If I just number it Tool 6 it will post with T106, then I get "ChkPgm line 9: No setup compatible with process requested (T=106).
adze_cnc
Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
Re: Xilog3 questions
Post by adze_cnc »
Is every tool number prefixed by the same letter "E"?
dustboy
Post by dustboy »
'E' is the prefix for tool changer tools (E1-E96), then there are "fixed" tools in the boring head with no prefix (1-96).
adze_cnc
Post by adze_cnc »
Would the boring head tools be used in tooplaths in the Vectric software?
Perhaps this user-written gadget (modified appropriately for your situation) might be of use? Tool Renumber
dustboy
Post by dustboy »
I'd be happy if I could run Vectric programs with the ATC spindle, the boring head tools are not crucial to me.
I tried the "Morbidelli Xilog Plus Arcs (mm)" post and I get a tool collision error on a simple pocketing operation. The gcode is calling out T6 which probably means boring tool 6, maybe the control is seeing X/Y motion while a drill is below the material surface?
Also the header is showing "DY=0.00" while the other X and Z dimensions are correct. "D" indicates the material dimension.
Post by Rcnewcomb »
What does the TOOLCHAGE section of your post processor look like? Is it something like this?
Code: Select all
+  Commands output at toolchange
begin TOOLCHANGE
"[N] M5"
"[N] G53 Z0"
"[N]  "
"[N] [91][TOOLNAME][93]"
"[N] T[T] [91] GET TOOL NUMBER [T] [93]"
"[N]  "
"[N] [S] [91] SET SPINDLE SPEED RPM [93]"
"[N] M3 [91]SPINDLE ON[93]"
"[N]  "
"[N] G53 Z0"
"[N] "
"[N]  F[FC] XY [91]SET FEEDRATE FOR X AND Y[93]"
"[N]  F[FP] Z [91]SET FEEDRATE FOR Z[93]"
"[N]  "
"[N] G00 [XH] [YH]"
"[N] G00 [ZH]"
