Hi guys.
I want to incoporate a script that sets the zero of the three axis in one go, using a touch plate but I can't find any on youtube that does that, there are some videos on you tube but not the scripts.
The best ones I have found are from Charlie Sarsfield, as they can work both in inches and mm but they set the axis individually one at a time.
Any help will be appreciated.
XYZ Zero setting script for Mach3?
- Model of CNC Machine: Alpha CNC 6090 with 4th Axis
Re: XYZ Zero setting script for Mach3?
Check out youtube.
I just searched for: xyz setting plate on cnc router
This should help.
Jim
This should help.
Jim
